What is it?
The only markings are a patent date of Apr 6 99 and a trade mark of two parallel arcs with a single line connecting in the middle.
(quoted from post at 20:26:37 07/10/14) A trocar is hollow....
trocar is solid awl in a hollow sheat.
When you stick a cow you hold the sheat down and pull the trocar out.
I used them plenty when i had dairy cows,..got still one of these devices kicking around somewhere.
I go with the awl with an adjustable depth stop
I don't buy that as a depth stop.
It's too complicated, and if it were some kind of an awl, it's awfully fat to need a depth stop - if you're puncturing something with it, it just couldn't be all that accurate to require a depth stop.
I'm voting for one end of a beam compass as somebody else suggested.
That "stop" looks MUCH more like a no-mar clamp. To clamp on a beam (like a yardstick) without hacking the beam up with a set screw when it's tightened.
It's a Trammel Point, used with a long steel ruler as a Beam Compass to make large circles, or to duplicate the radius of an arc.
You are missing the steel ruler and scribe holder, to make it a complete unit.
