Stan in Oly, WA
A neighbor asked me if I could repair a galvanized watering can that the spout broke off of. Someone had put a hose fitting and small pump in it to make it a sort of rustic fountain. None of that is my problem, though. I just have to get the spout back on.
The metal is 20 gauge at the most. It appears that the original method of attachment was solder. I don't have any heat source for soldering except for propane or oxy/acetylene. I'm only a little concerned about zinc fumes, because I could set up a fan to blow the smoke and fumes away from me. Could I solder this with plumbing solder and flux, which I have, or do I have to buy a more appropriate type? Any advice about the best way to fix this?
Thanks, Stan
Similar watering can
Thanks, Stan
