Yesterday's Tractor Co.
Shop Now View Cart
Tool Talk Discussion Forum
Re: Heat Pump Water Heater- Need Help
06-27-2014 07:10:11
Thanks George. Sometimes it doesn't take much to confuse me.
This did it, came back from my shop with the wires to connect that extra capacitor. Then I looked at the wiring diagram again. The Run wire goes directly to L1, hidden interconnection on the black capacitor. Confirmed that with those resistance measurements you suggested.
Only the Start wire has the benefit of that 15 mfd capacitor. Did you mean in parallel to the Start cap? What you wrote was "wired in parallel with run cap", doesn't appear there is one.
Knowing nothing about these, I'm hesitant to experiment without expert help. Yours is appreciated.
George Marsh
06-28-2014 11:46:21
 Re: Heat Pump Water Heater- Need Help in reply to VaTom, 06-27-2014 07:10:11
Yes, one side of the start cap goes to the start terminal of comp and the other side goes to the run side of comp. That will mean the two capacitors are in parallel. Only power up for a second to two. Compressor should start if it's not locked up or burned up internally. If compressor is good, then order a HS kit from ebay or get from a person in the HVAC business. Doubt if a supply house will sell to you. Wish you had a larger voltage on start cap, so if it doesn't blow you should be good, if not you will have a little excitement.
