Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Tool Talk Discussion Forum
Re: JB Weld Auto Body Patch Adhesive??
Glenn F.
06-23-2014 15:44:25
Thank you glennster. I will get some. Final hole is about 1.3 x 12 inches along rear wheelwell on '88 Chevy. I have good steel all around tbe rust hole. Should I somehow try to glue patch from the inside? I would have to drill a couple holes in the patch & pull it out with some hooks. It would make tbe body work easier, but I'm not sure I can do it with no rear access. What would you do?
Thanks,
Glenn F.
LOU from Wi.
06-23-2014 18:08:27
 Re: JB Weld Auto Body Patch Adhesive?? in reply to Glenn F., 06-23-2014 15:44:25
Glenn F. If you are unsure of it, you could always drill it for rivets, dimple the holes and pop rivet it into place with the panel adhesive. Just a couple of extra steps,but the vibration won't tear it loose, and you won't have to worry about heat warping the metal.
Regards,
LOU
