Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Tool Talk Discussion Forum
Re: JB Weld Auto Body Patch Adhesive??
glennster
06-23-2014 13:25:45
it may hold for a while. we use semm panel adhesive here at the shop. you will tear the metal before the adhesive will let go.
IH2444
06-23-2014 19:35:10
 Re: JB Weld Auto Body Patch Adhesive?? in reply to glennster, 06-23-2014 13:25:45
glennster said: (quoted from post at 16:25:45 06/23/14) it may hold for a while. we use semm panel adhesive here at the shop. you will tear the metal before the adhesive will let go.
poke here
Not cheap though, need a $57 gun and some $2 tips as well as the semm.
This post was edited by IH2444 at 19:35:26 06/23/14.
Glenn F.
06-23-2014 15:44:25
Thank you glennster. I will get some. Final hole is about 1.3 x 12 inches along rear wheelwell on '88 Chevy. I have good steel all around tbe rust hole. Should I somehow try to glue patch from the inside? I would have to drill a couple holes in the patch & pull it out with some hooks. It would make tbe body work easier, but I'm not sure I can do it with no rear access. What would you do?
Thanks,
Glenn F.
LOU from Wi.
06-23-2014 18:08:27
 Re: JB Weld Auto Body Patch Adhesive?? in reply to Glenn F., 06-23-2014 15:44:25
Glenn F. If you are unsure of it, you could always drill it for rivets, dimple the holes and pop rivet it into place with the panel adhesive. Just a couple of extra steps,but the vibration won't tear it loose, and you won't have to worry about heat warping the metal.
Regards,
LOU
Copyright © 1997-2015 Yesterday's Tractor Co.
