TractorLinks.com
Tool Talk Discussion Forum
cistern
Ellis Kinney
06-22-2014 17:29:35
I live in Northern Ky. and have a cistern on my farm. In this neck of the woods we call them jug or bottle cisterns because of the shape. It is about 21' deep and about 11' in diameter at the bottom. It normally holds water to about 7' from the top. If it fills any more than that it will return to the 7' from the top level in a couple of days, but doesn't go any lower except with use. The cistern has rock walls and is plastered.Would there be any chemical or solution or powder that expands in a crack that would slow or stop the leak? Thanks, Ellis
Ellis Kinney
06-23-2014 17:20:41
 Re: cistern in reply to Ellis Kinney, 06-22-2014 17:29:35
Thanks for all the info. There is no over flow in the cistern. Ellis
rd 2n in mo
06-23-2014 07:08:15
sounds like your water table is at the 7' mark. you can try the hydralic cement but if you don't know where the leek is you will be chasing it forever.
IH2444
06-23-2014 08:39:12
 Re: cistern in reply to rd 2n in mo, 06-23-2014 07:08:15
Yeah sounds like water is leaking as much as leaking out.
Duner Wi
06-23-2014 04:17:57
I don't think this stuff expands but it does cover hair line cracks well.
http://www.chargar.com/Products/prod_na.html
Ian Beale
06-23-2014 01:55:37
Here (Oz) we can get this product for concrete tanks
http://www.crystalfix.com.au/
Seems to work - we've done the reinforce as they recommend with deformed bar on one concrete tank (above ground) and have cut back from a torrent to a dribble.
A professional concreter should be able to point you your side
504
06-22-2014 19:18:57
Are you sure there is not an overflow drain in it? Ours will flow to a drain that is 600ft from the house when full.
Paul
06-22-2014 21:59:29
 Re: cistern in reply to 504, 06-22-2014 19:18:57
That is what I was thinning, overflow drain?
Paul
greg k
06-22-2014 18:46:53
I would also vote for the hydraulic cement. Bentonite is just clay, basically dirt but it should work.
JerryD
06-22-2014 18:30:09
Have you thought of HYDRAULIC CEMENT? it will set up in running water.
Steve@Advance
06-22-2014 17:51:42
Expanding foam?
VaTom
06-22-2014 17:49:22
Bentonite is an expansive clay that works like that. Available in several forms, excellent water-proofing. Our state Health Dept. strongly recommends it for water wells to keep out surface water.
Diydave
06-22-2014 18:24:25
 Re: cistern in reply to VaTom, 06-22-2014 17:49:22
Yes, bentonite, it comes in several grades, you can get it from drillers supply, they might have a branch near you. or ask a well driller...
