Yesterday's Tractor Co.
Shop Now View Cart
Tool Talk Discussion Forum
Re: Heat Pump Water Heater- Need Help
06-22-2014 16:26:56
Sounds like the original cap was a dual... As in 2 caps in one can. This can be replaced with 2 separate caps. Since you don't have the original, you'll need to determine the Mfd needed. Do you know the volts, amps of the compressor?
06-22-2014 17:41:51
 Re: Heat Pump Water Heater- Need Help in reply to Steve@Advance, 06-22-2014 16:26:56
Thank you Steve, those diagrams help. I have one of the original capacitors, the one that smoked up the house. AD apparently is the brand, 15 mfd (10%), 370v.
There's an unlableled component that the compressor common goes to. Maybe a relay. Doesn't look like one to me, but this rectilinear capacitor could have fooled me if it wasn't labeled.
I bought a pair (I like spares) of CSC 15 mfd (6%) 370v. from McMaster-Carr. I'll try using both. I wasn't aware dual was a possibility. Only 1 line voltage into the original capacitor, with two wires going out to the compressor, labeled S and R on the wiring diagram.
Difficult to figure out when you don't know what's required to make something work.
I was guessing the first diagram in that link was correct, but it didn't work. Of course I also don't know if this compressor is going to work. It was never used, just sat for close to 20 years.
You've been around YT since 2013, wouldn't remember T_Bone? I had a problem with a mismatch between the HPWH and my electronic controlled tank heater. The Whirlpool and Crispaire techs conferred and said they wouldn't work together. T_Bone helped me work it out, how I became friends with him. Amazing what expertise one can find on these boards.
06-23-2014 06:02:39
 Re: Heat Pump Water Heater- Need Help in reply to VaTom, 06-22-2014 17:41:51
sure do miss T_Bone
06-23-2014 06:31:48
 Re: Heat Pump Water Heater- Need Help in reply to evilboweivel, 06-23-2014 06:02:39
Me too. Though I don't know if he knew more of capacitors than I do.
Heard no more from his widow after she apparently was interviewing me. I explained I was spoken for a long time ago, just trying to be helpful to her. One last favor for an old friend.
I finally found the car I wanted for a road trip and got the title cleared up on the Arizona mountain land I invited him to summer on. Could have made it out there this year, but he didn't stay around.
06-22-2014 17:46:58
See if you can track down George Marsh. Bet he can help you.
06-22-2014 17:59:03
 Calling George Marsh in reply to Steve@Advance, 06-22-2014 17:46:58
Thanks Steve.
06-23-2014 15:28:23
 Re: Calling George Marsh in reply to VaTom, 06-22-2014 17:59:03
Steve, George doesn't appear interested.
I did locate the current company, different name, who hasn't manufactured these units for so long the tech I spoke with had never seen one. He's been with the company 14 years.
I had to scan the wiring diagram for him.
Not a double capacitor, my first guess about how to hook it up was correct. Seems the compressor died a natural death, without ever doing any work.
Thank you for the effort.
