Off delay timer relay
Hello, I was wondering if anyone knew where I could find a 12vDC off delay timer that could be set for 10 to 15 min? That I want to use on the heated mirrors of a truck so the power will turn off to them after so long. Thanks for any help
Grainger has one that offers multifunction capabilities, and is operated on 12V DC. I was looking for one awhile back, for another 12VDC application and finding them for the low, DC voltage is nearly impossible. In this case your pretty much stuck with an 8 pin design due to the time frame your needing. If you wanted a shorter time delay you could find a solid state one that would fit the bill just as well.
Grainger
