TractorLinks.com
Tool Talk Discussion Forum
Re: What is this tool used for?
tom upton
06-10-2014 19:43:35
It is a machinist level, mostly used for machine set up/precision leveling. each graduation on the main vial is .005/ft. To check and calibrate you need a nice flat and level surface , a granite surface plate or mill bed will do. Mark spot you set level then turn end for end and set in same spot. It should read the same. If not you will need to adjust until the same. To get an idea how sensitive this level is put your finger on the end of the vial you want the bubble to go towards. If it is within a couple graduations already the heat from your finger will make bubble move towards your finger. They make an even more precise level than this called a master level that is graduated in .0005/ft maybe even finer.
