bfullmer
Anyone have a simple tool to hold up the 3 pt arms while
mowing? I have a small kubota that I mow with a 60" deck and
I would like to keep three point trailer hitch on but it digs in on
hills-- it is a pain to keep taking off hitch?
use a length of chain, lift 3pth, the chain from top link mount down to lower link level, either the link pins or a crossbar on your trailer hitch, get the chain as tight as possible, and then the arms won't lower much.
There was a post on about keeping the front up on a bushhog just a day or so ago.
There is a kit with chains that pins to where the top link goes on the tractor and the other end hooks to the lower pins out at the hitch/drawbar. if your lower pins on your trailer hitch bolt on, the kit has plates to bolt under the pins to make the lower end permanently fastened on.
I have one on my bushhog that I use with a MM 335 with a weak 3-point lift.
doesn"t your three point arms control the lift on your deck? They don"t come down and your deck won"t come down
