Yesterday's Tractor Co.
Shop Now View Cart
Tool Talk Discussion Forum
Re: sparky GFI question
06-09-2014 16:25:40
A cheap tool everyone should own is an outlet polarity tester with GFCI test. In a minute or two, you can verify every outlet in your house is properly wired, and test the GFCIs at the same time.
Stan in Oly, WA
06-09-2014 22:03:24
 Re: sparky GFI question in reply to MarkB_MI, 06-09-2014 16:25:40
Hi Mark;
The description of that tester reads:
120 VAC GFCI Outlet Tester; 1/clam, 5 clams/master
What does the part about clams mean?
06-10-2014 01:27:49
 Re: sparky GFI question in reply to Stan in Oly, WA, 06-09-2014 22:03:24
Stan, that gave me pause, too. It's been 35 years since I picked up my degree in electrical engineering, but I think I would remember if there was an electrical unit of measure named "clams".
I think that's packaging information that HD probably didn't intend to show up in the product description. Translation: one unit per clamshell package, 5 clamshell packages per box.
06-09-2014 17:10:42
Quoting Removed, click Modern View to does it detect a ground/neutral swap?
06-09-2014 19:08:24
 Re: sparky GFI question in reply to JMOR, 06-09-2014 17:10:42
There are certain faults it can't detect. Such as a ground-neutral swap, since ground and neutral are at the same potential.
dr sportster
06-09-2014 19:28:59
 Re: sparky GFI question in reply to MarkB_MI, 06-09-2014 19:08:24
No I'm delirious because the Rangers are losing . No such test. How would that work anyway? NEVERMIND>
dr sportster
06-09-2014 19:14:09
I beleive the Gardner-Bender one does that . There are seven ways it lights the lights to test. Pretty sure one is ground /neutral swap.
