Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Tool Talk Discussion Forum
Re: Furnace ductwork question?
jeffcat
06-08-2014 17:48:00
If you already installed everything you can measure the flow with an aroemeter. they look like a little wind turbine on the top of a short pole. A little pocket one is at many kite shops and looks like a plastic paddle with a little gauge. Figuring ducts, I would ask at a fabrication shop for heat ducts or a store like for heating and air conditioning and refrigeration. National refrigeration.Etc. Jeffcat
evilboweivel
06-09-2014 09:59:03
 Re: Furnace ductwork question? in reply to jeffcat, 06-08-2014 17:48:00
need more info!! what size furnace?
what you can do with what you have already is to cut holes with a hole saw in the duct until the static pressure drops in the duct to about .5 to .75 at that time you will be roughly right.
HOWEVER you probably will not get enough air flow across the heat exchanger with the 12" main duct and your furnace will cycle on the high limit.
If you are in the mid south based on your handle then you need to add more ceiling insulation and propably ok on sidewall insulation
In the north way short on insulation
Good luck
Ron
wgm
06-09-2014 03:10:00
Those things are a joke. The only accurate way to measure air flow is by doing a pitot traverse.
