TractorLinks.com
Tool Talk Discussion Forum
Re: a/c compresser
John T
06-08-2014 07:32:50
On allllllll the ones Ive owned if Freon was low the electric clutch never engages so they indeed turn pretty easy as its only a small bit of bearing friction if alls well in the clutch and bearing assembly. If Freon is present and at the correct pressures and the thermostat calls for cooling, its only then the clutch engages and she indeed turns much harder then. If freon is low there must be a leak and unfortunately its often the compressor grrrrrrrrr. Ive had some that leaked slowly so the compressor clutch never engages but as soon as I hang a can on her she will eventually start to engage and short cycle a bit until theres enough freon and she works fine until she leaks out which may be almost an entire summer if its only a slow leak but otherwise its compressor time............
John T
