TractorLinks.com
Tool Talk Discussion Forum
Re: a/c compresser
Schrade
06-08-2014 07:05:04
A friend said if it turns easy it is no good, but if it is doesn't have Freon should it. Don't want to waste money putting gas in if compressor is junk
Steve@Advance
06-08-2014 15:13:31
 Re: a/c compresser in reply to Schrade, 06-08-2014 07:05:04
Typically if the refrigerant has leaked out, the compressor will turn with minimal effort. Since it has likely leaked out, look for oily residue around the clutch, slung on the bottom of the hood, fender well, etc. That will indicate the shaft seal is leaking.
The same dirty oil residue on any other component will indicate a leak.
The good thing about the compressor turning easily and smoothly is there hasn't likely been a mechanical failure in the system. Once that happens, it is near impossible to get all the shrapnel out of the system.
John T
06-08-2014 07:32:50
On allllllll the ones Ive owned if Freon was low the electric clutch never engages so they indeed turn pretty easy as its only a small bit of bearing friction if alls well in the clutch and bearing assembly. If Freon is present and at the correct pressures and the thermostat calls for cooling, its only then the clutch engages and she indeed turns much harder then. If freon is low there must be a leak and unfortunately its often the compressor grrrrrrrrr. Ive had some that leaked slowly so the compressor clutch never engages but as soon as I hang a can on her she will eventually start to engage and short cycle a bit until theres enough freon and she works fine until she leaks out which may be almost an entire summer if its only a slow leak but otherwise its compressor time............
John T
