TractorLinks.com
Tool Talk Discussion Forum
Re: Automotive A/C leak detector question
pete 23
06-07-2014 11:26:49
Like others have said, no one answer to finding a ac leak. Some leak under high pressure, some low pressure, some when hot, some when cool. I though dye was the answer, found out it was not. Electronic leak detector has found a lot of leaks for me, missed a lot also. Some compressor seals will not hold a vacuum but still not leak refrigerant. . Others will hold vacuum and then leak refrigerant. Some hose will hold vacuum but leak pressure. Drive you crazy if you let it. Usually a leak you cannot pinpoint that leaks out quite rapidly is indeed the compressor. Have seen that many, many times.
