Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Tool Talk Discussion Forum
Re: Automotive A/C leak detector question
Hobo,NC
06-07-2014 08:35:25
If this wont find it its not worth going after... I have 2 of'em I paid full price for the first one and picked the other up on Craigslist cheap...
http://www.ebay.com/itm/like/221113932429?lpid=82
I also have a Bacharach H-10PM but its has a price :shock:
http://www.jbtoolsales.com/yokogawa-3015-0627-all-in-one-refrigerant-leak-detector-r12-r134a/?gclid=CJi6qd-K6L4CFStk7Aod33oACA
These are the only electronic leak detectors I trust...
JMOR
06-07-2014 08:57:30
 Re: Automotive A/C leak detector question in reply to Hobo,NC, 06-07-2014 08:35:25
But, as I said, "You can buy a $500 unit specified to detect 1/10 of an ounce per year leak & still not find an evaporator leak, because the evap is so inaccessible that the refrigerant leak will disperse so much as to be undetectable before the sensor sees it. Eventually the UV dye from the evap leak will mix with the condensate and you see it there."
That is my experience with this $500 unit. If you can sniff a small leak in evap while still installed in duct work, you do better than I have been able to do.
http://products.inficon.com/en-us/nav-products/Product/Detail/D-TEK%20Select?path=Products%2Fpg_ServiceToolsforHVAC_R
This post was edited by JMOR at 09:34:22 06/07/14.
Hobo,NC
06-07-2014 18:13:09
 Re: Automotive A/C leak detector question in reply to JMOR, 06-07-2014 08:57:30
You sniff at the drain are if it has a blower resister remove it for a good shot at the evap...
The TEK-Mate is some times to sensitive on a large leak its then I use the Yokogawa to nail the leak...
