TractorLinks.com
Tool Talk Discussion Forum
Re: Automotive A/C leak detector question
JMOR
06-07-2014 06:04:57
Quoting Removed, click Modern View to seeYou can buy a $500 unit specified to detect 1/10 of an ounce per year leak & still not find an evaporator leak, because the evap is so inaccessible that the refrigerant leak will disperse so much as to be undetectable before the sensor sees it. Eventually the UV dye from the evap leak will mix with the condensate and you see it there.
George Marsh
06-07-2014 16:11:54
 Re: Automotive A/C leak detector question in reply to JMOR, 06-07-2014 06:04:57
Jessie I had a 91 grand caravan. It had one leak after another. Replaced evaporator, expansion valve, then the steel lines going to the rear evaporator had many pin hole leaks, then I got rid of van. It became a money pit after 15 years and 150K.
I have seen so many AC, dehumidifier, refrigerator and heat pump leaks, it's hard to say where you will find them.
I've concluded that anything that has freon it it, if it doesn't leak, just wait, it may leak tomorrow. I sometimes think some leaks are caused by the very thin, cheap copper and aluminum used. Then sometimes, it's gasses like 410a that run at such high pressures.
It's no wonder the HVAC people make a good living with service calls. It reminds me of the old TV repairman making service calls to replace vacuum tubes.
