TractorLinks.com
Tool Talk Discussion Forum
Re: Air Pressure adjustment on compressor
Steve@Advance
06-05-2014 12:45:08
There should be a brand name and model # on the pressure switch. Should be able to find the info doing a search.
If not, one screw will be the pressure, the other will be the differential.
With the tank pumped up to 90, start turning one in, count the turns so you can put it back. It should come on within 2 turns. If not, put it back and try the other. Once you determine which is the pressure screw and which is the differential, you can fine tune it through a few cycles.
Brent in IA
06-06-2014 06:27:02
 Re: Air Pressure adjustment on compressor in reply to Steve@Advance, 06-05-2014 12:45:08
That makes sense...like setting the fan temp offset in a hog building! Thanks.
