Gas torch assembly
Tequila
Have a medium duty Victor weld and cutting assembly that needs the O-rings replaced. I have tried several supply houses,( hardware-parts houses and two welding supply) no one has the correct sizes. Anyone familiar with where I might find them. Thanks
If you google it they are 1.50 and 1.75 a set but the problem with these online stores is they usually have a minimum order amount. So unless you need some gloves or caps or lenses ... well you could try ebay. Cyberweld is not a Victor distributor as far as I can tell.
There is a place in california called Seal Seat. www.sealseat.com Tel #18009722233. I got o rings for my old harris torch from them . They have parts for all brands of gas welding eqpt.I think min. order was $20...... Rich
Ace hardware I've got an old set of Harris torches less than a buck to replace o rings good as new
