Yesterday's Tractor Co.
Shop Now View Cart
Tool Talk Discussion Forum
Re: McCulloch Mini Mac 35 fuel type
06-04-2014 11:44:21
When the manual was written, regular was probably leaded gasoline. Times change, probably for the better in this case, at least as far as our lungs are concerned.
Fortunately, the lead really served no purpose in 2-stroke engines, so the current "regular" unleaded gasoline is perfectly fine.
Some will argue that the ethanol will ruin your fuel system and that you need to find ethanol-free gasoline, or use that expensive $7/quart premix from the chainsaw store.
On an old chainsaw like your Minimac 35, that probably hasn't been run in decades, I am confident in saying that the fuel system is *ALREADY* a bunch of melted rubber mush, and it hasn't seen a drop of ethanol.
Explain that, you anti-ethanol types...
06-07-2014 08:06:35
 Re: McCulloch Mini Mac 35 fuel type in reply to mkirsch, 06-04-2014 11:44:21
No explanation required or given. There are reasons to be FOR or AGAINST ethanol. My main objection to ethanol is the lack of CHOICE. It has been forced upon us prematurely.
FACT: ethanol contains LESS BTUs per unit than gasoline.
FACT: ethanol DOES attack some plastic and rubber compounds.
FACT: ethanol absorbs moisture from the air. This causes phase separation which leads to a short shelf life .
The damage is real. Your statement that you never had a problem does NOT invalidate all other claims of damage. I have seen many engines on outdoor equipment have varying amounts of ethanol damage - from no damage to extensive damage. For some reason, some equipment tolerates the ethanol better than others.
Given a free choice, the ethanol would disappear as it has in the past when marketed as an "alternative" fuel. I do remember the "gasohol" of the 1970s. And again in the '80s. This time it is force fed to us. I still like to have a choice in the matter.
Oh....back to the chainsaw....
MOST fuel available when that saw was built was unleaded. The last of the leaded fuels available for on-road use were pretty much gone before 1980. Is the saw older than 35 years????
06-04-2014 13:29:24
"Fortunately, the lead really served no purpose in 2-stroke engines."
Untrue, 2 stroke engines will detonate due to fuel with too low octane same as 4 stroke.
