TractorLinks.com
Tool Talk Discussion Forum
Re: An electrical question
greg k
06-04-2014 05:46:26
Well, the best step here is to ask a local electrician since he should familiar with local codes. Unless there is over current protection (fuses or breakers) before these panels they are not considered sub panels. If they are not sub panels then the neutral and ground are bonded at the panel with a driven ground rod or grounding plate. If these panels are sub panels then it is grandfathered in but you may see better conditions for the radio if there is a separate ground. Boring a new feed under the landscaped area may be an option. The overhead is an easy fix by adding a wire or converting to triplex.
