Yesterday's Tractor Co.
Shop Now View Cart
Tool Talk Discussion Forum
Re: Remote controlls
big fred
06-03-2014 22:06:32
Mechanical shock and vibration can damage electronics, but it's pretty rare nowadays. Much more common is damage from corrosion or heat. You wouldn't necessarily see the corrosion without a microscope, and you wouldn't see a thermal failure at all. My guess is that you have a bit of grunge on the contacts in the battery compartment.
Chris Jones
06-04-2014 06:13:26
 Re: Remote controlls in reply to big fred, 06-03-2014 22:06:32
No, they're clean. As I mentioned the opener remote's indicator light shines brightly when the button is pressed which proves the battery and connections are fine--but it must not be transmitting the rf--remember all other remotes still work and I've tried this one right beside the opener in case the single is just weak. Also keep in mind this is a late 1980's opener with dip switches so there is no having to learn each remote just set the switches the same and it works.
JS305 helped me find out the DVD player itself is likely the problem there as the IR LED on the remote lights bright when a button is pressed (seen via digital camera).
