Yesterday's Tractor Co. Restoration Quality Tractor Parts
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Tool Talk Discussion Forum
rotor removal rear 2004 jeep grand cherokee
wfw
06-03-2014 07:24:23
71.53.100.1
the left rear caliper went bad on my jeep and I am having to replace it. since the rotors are too thin from the factory( way for the dealership to make more money) I thought I would replace them at the same time. does anyone know how they come off? I have the caliper off haven't tried to get the rotor off yet. it would not just pull off but may be stuck. I am going to replace both back rotors, the front has already been replaced several years ago( not by dealer). thanks for any and all help.
frank
[Reply]   [No Email]
wfw
06-06-2014 19:05:58
184.3.80.236
 Re: rotor removal rear 2004 jeep grand cherokee in reply to wfw, 06-03-2014 07:24:23
the rotor had clips on two of the studs. I removed the clips and getting the rotors off was easy. the reason I changed the rotor is I took it in for inspection and they found the caliper was leaking. they said the rotor was "too thin" and would have to be replaced also, the new rotor looks to be the same thickness as the old rotor. the dealer back in 2004 tried to get me on the too thin rotor on the front. I changed them about a year later and they were much thinner then the new ones. I cannot see paying some one to change the rotors at $300 when I can do it myself. the place I tried to get inspected wanted $415 to change the caliper, rotors, and pads on the rear. cost me $185 in parts(advance auto). big difference.
frank
[Reply]  [No Email]
dave in
06-05-2014 02:39:36
216.8.231.233
I have an 04 jeep grand Cherokee and there is nothing holding them other than that there rust to the axel it took a mini sledge to get them to brake loose on mine .
[Reply]  [No Email]
markiz41
06-04-2014 05:44:56
129.139.1.75
I bet the emergency brake is set up like the old style drum on the same rotor. They get pretty tight from rust and little clearance to begin with. They'll come off with your choice of persuasion.
[Reply]  [No Email]
Tvertiz
06-03-2014 19:14:54
71.218.200.34
Also you do need to check for screws holding them on or emergency brake that is on.
[Reply]  [No Email]
Tvertiz
06-03-2014 19:13:13
71.218.200.34
Hopefully I did this link right, this method is as good as gold in my opinion.
PS
YouTube has almost every answer for automotive stuff.
[Reply]  [No Email]
Mike Groom
06-03-2014 16:04:39
69.197.94.120
I think the emergency brake is inside so you have to turn the star wheels for the shoes to get the drum off the inside brake shoes,if you look on the back side you will see the slot for this.
[Reply]  [No Email]
ypop
06-03-2014 15:14:55
24.141.176.236
once I had to cut off the front rotors of a Ford Torus used a grinder when the metal starts turning blue its thin enough to break when hit.
[Reply]  [No Email]
SDE
06-03-2014 11:24:47
174.124.11.16
Rotors may be held on by a clip over one of the studs. Pry it off. The rotor will be rusted on to the axle. Tap on the rotor to loosen it by going around in a circular pattern. Eventually it will be loose and you can pull it off.
SDE
[Reply]  [No Email]
Wsmm
06-03-2014 10:15:01
74.203.248.76
Try these sites. nagca.org or jeepforum.com
[Reply]  [No Email]
gab
06-03-2014 10:05:07
50.103.20.111
Some rotors have a small screw between 2 of the studs, if you can't find a screw use you're favorite penetrant around the studs and axle and start pounding, sometimes a little heat is also helpful. Careful ,don't hit a stud.
[Reply]  [No Email]
JRSutton
06-03-2014 11:19:14
71.174.108.245
 Re: rotor removal rear 2004 jeep grand cherokee in reply to gab, 06-03-2014 10:05:07
not sure if the 2004 jeeps have those screws (often 2 philips head). They should be obvious.
If it does - I HIGHLY recommend purchasing an impact screw drive if you don't already own one.
The kind you hit with a hammer.
If it doesn't use those screws, it's likely just rusted in place.
get a good 3 to 5 pound hammer and smack the rotor off from the back if you can get around the shield.
It'll come off with some convincing. They can get very stuck.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Posting Help]  [Return to Forum]   [Add a Reply]
TRACTOR   PARTS TRACTOR   MANUALS
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2014 Yesterday's Tractor Co.
