TractorLinks.com
Tool Talk Discussion Forum
Re: Simultaneous starter and battery failure
Determined
06-02-2014 21:55:56
If it makes you feel better. Yes it can happen, chain reaction effect.
Say your battery had a failing cell, with low battery voltage the starter motor draws higher amps, solenoid contacts arc and starter stays engaged, shortening it's life span down to minutes.
Burnt contacts cause intermitent starting.
Once the starter motor has overheated or run engaged;
-Brushes worn down to nothing.
-Armature glazed up.
-Bearing/bushings melted.
-Overheated connections become loose etc.
Doesn't happen every time or day but it does happen.
