TractorLinks.com
Tool Talk Discussion Forum
Re: Motor brushes
DGinVT
06-01-2014 05:46:59
Two thoughts come to mind: You might be able to drill a small hole in the brush and reattach the lead with epoxy or put a small bolt through the hole with and reattach the brush that way. Find a larger brush and carefully sand or file it down to fit. There are many sources for brushes around.
Slowpoke
06-01-2014 16:16:54
 Re: Motor brushes in reply to DGinVT, 06-01-2014 05:46:59
HI DGinVT
That's what I was thinking, but will electricaly conductive epoxy bond to the carbon brush? They seem very slippery. Most of these projects are a one try deal and if it doesn't work, the money spent may as well have gone into buying a new part. But by then it's too late.
I've also thought about the mechanical repair with a pin or screw.
DGinVT
06-02-2014 05:40:29
 Re: Motor brushes in reply to Slowpoke, 06-01-2014 16:16:54
A mechanical repair would be the best. with a small hole thru the brush. There will be heat generated from the electrical current and the epoxy may try and burn off or melt.
Slowpoke
06-02-2014 16:01:08
 Re: Motor brushes in reply to DGinVT, 06-02-2014 05:40:29
DGin VT,
A friend suggested cutting a flat piece of copper the size of the top of the brush, silver soldering the lead to it in the center, slip on the spring and install it. I was thinking of adding some electricaly conductive grease or paste between the brush and copper plate. Something like an automotive EC grease which can stand elevated underhood temperatures.
Slowpoke
DGinVT
06-02-2014 17:31:59
 Re: Motor brushes in reply to Slowpoke, 06-02-2014 16:01:08
I think your solution will work quite nicely. One has to be inventive these days.
George Marsh
06-01-2014 06:05:14
I couldn't find a source to replace the brushes for a crapsman shop vac. I just waited for them to go on sale and bought a new vac.
I did get a new set of brushes for my old B&D right angle grinder, but they cost more than I could have bought a new grinder from China. The old B&D grinder is worth fixing.
