20 D Massey 3 point pump
excaliburgc
New User
Replaced the 3 point pump 2 times now, everything installed correctly.. old pump and 2 replacement pumps split apart in less than 20 seconds. bending push rod, braking cast iron pump pushed hole thur piston and bending front studs and or pulling threads out of pump.. please what is wrong..
you are pumping to a closed system , the oil has no place to go , check the return if you can turn it by hand to check it
thank you don't mean to sound stupid but when you are its easy.. what quick coupler? and how do I go about checking return,
thanks in advance
(quoted from post at 03:43:51 10/31/14) thank you don't mean to sound stupid but when you are its easy.. what quick coupler? and how do I go about checking return,
thanks in advance
It is not very likely that your tractor has any quick coupler non it.
