TractorLinks.com
Tool Talk Discussion Forum
20 D Massey 3 point pump
excaliburgc
05-31-2014 09:15:21
Replaced the 3 point pump 2 times now, everything installed correctly.. old pump and 2 replacement pumps split apart in less than 20 seconds. bending push rod, braking cast iron pump pushed hole thur piston and bending front studs and or pulling threads out of pump.. please what is wrong..
Stick welding
05-31-2014 16:02:28
 Re: 20 D Massey 3 point pump in reply to excaliburgc, 05-31-2014 09:15:21
Ask on the Massey forum. Sure sounds like it's dead heading and/or the relief valve isn't working properly.
Billpa
05-31-2014 09:57:55
you are pumping to a closed system , the oil has no place to go , check the return if you can turn it by hand to check it
Billpa
05-31-2014 10:02:12
 Re: 20 D Massey 3 point pump in reply to Billpa, 05-31-2014 09:57:55
my guess is a hose with a quick-coupler is not hooked up
