Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Tool Talk Discussion Forum
Re: Lift problems on a 59 Ford 641-D
JMOR
05-30-2014 18:13:19
Quoting Removed, click Modern View to seeFO-20 is an I&T manual available all over the place, including most tractor supply places.
59-641-D
06-06-2014 13:34:00
 Re: Lift problems on a 59 Ford 641-D in reply to JMOR, 05-30-2014 18:13:19
Ok, update.....pulled the cover sent it out for complete overhaul...dropped the plate for the pressure rielief valve.....sludge in the bottom....(mind you this was flushed back in 2008) and sludge in the case itself) get to clean it again. As far as the O-rings, they looked a little chewed and will be replaced with the gasket. I will look into the I&T manuel for the future.....will let you know what happens
JMOR
06-06-2014 13:48:10
 Re: Lift problems on a 59 Ford 641-D in reply to 59-641-D, 06-06-2014 13:34:00
Good luck & do keep us informed.
59-641-D
06-17-2014 14:56:33
 Re: Lift problems on a 59 Ford 641-D in reply to JMOR, 06-06-2014 13:48:10
I will :D
59-641-D
06-23-2014 16:55:11
 Re: Lift problems on a 59 Ford 641-D in reply to 59-641-D, 06-17-2014 14:56:33
Lift is fixed, chatters slightly, maybe due to air in the system.
thanks again:)
JMOR
06-24-2014 05:19:59
 Re: Lift problems on a 59 Ford 641-D in reply to 59-641-D, 06-23-2014 16:55:11
Happy 'lifting'. :lol:
59-641-D
06-29-2014 07:19:45
 Re: Lift problems on a 59 Ford 641-D in reply to JMOR, 06-24-2014 05:19:59
Air is out, works beautifully:)
59-641-D
05-30-2014 18:20:30
this web site, or "Tractor Supply"??
Thanks,
Eddie
59-641-D
05-30-2014 18:24:05
 Re: Lift problems on a 59 Ford 641-D in reply to 59-641-D, 05-30-2014 18:20:30
or does Ford new holland have it???
