TractorLinks.com
Tool Talk Discussion Forum
Lift problems on a 59 Ford 641-D
59-641-D
05-30-2014 17:33:57
I'm trying to locate part #NCA503B and NCA502 so I can adjust the constant draft. One is a guage. the other postisions the arm so you can adjust it to spec. it's not picking up high enough and it chatters. The hight problem is adjustment, the chattering I wonder if the relief valve in the bottom of the case might be preventing the lift full pressure or the two O-RINGS where the top mounts are shot
Thanks,
Eddie
Paul
05-31-2014 07:20:33
 Re: Lift problems on a 59 Ford 641-D in reply to 59-641-D, 05-30-2014 17:33:57
Fella on here used to sell a spacer block and other parts to do this, can't ever remember his name right now. He got too busy to be very active on the forum?
Paul
JMOR
05-31-2014 05:53:44
Quoting Removed, click Modern View to seeActually there is nothing to those two "special tools". 503 simply holds the lift arm one inch above the cover gasket surface for duration of your adjustments. A 'stepper" ought to be able to rube goldberg that. 502 is a double ended feeler gauge with 0.39" thickness on one end for draft setting & 0.45" on the other for position adjust. A couple of 1/2 soft bolts (or scraps of iron), grinder or file & caliper ought to get that solved too.
JD Seller
05-30-2014 22:09:14
The IT manual is not as good as the Ford reproduction manual here on details but the IT manuals shows you how to do the adjustments without the factory tooling.
I think that YT sells the IT manuals but you would need to call them to make sure. I only found the Ford factory reprints on line. I know many of YT parts are from Tisco and Tisco used to sell the IT service manuals.
I personally like to have both manuals. The Factory reprints go into great detail but may only refer to some special tool to do something. Where the IT manual many times will show you how to do the same thing with common tools or how to make a setting tool.
JMOR
05-30-2014 17:44:28
Quoting Removed, click Modern View to seeIf the o-rings bad, you would see leaks. If relief opening too early, then it would still yield full lift at no or light loads. Those tools, having been out of production for decades, are very rare today, but..........there are "tool-less" alternate adjustment procedures in the FO-20. Surely you aren't trying to work on it without one?
59-641-D
05-30-2014 17:50:08
 Re: Lift problems on a 59 Ford 641-D in reply to JMOR, 05-30-2014 17:44:28
I just have the Shop manuel for it. what is the FO 20 and how do I find it??? I also read on this forum an I&T manuel????
59-641-D
05-30-2014 17:55:34
 Re: Lift problems on a 59 Ford 641-D in reply to 59-641-D, 05-30-2014 17:50:08
In the past, I'd pull the cover and send it out to be adjusted, but I dont think there's many people that deal with tractors this old and they charge too much for something I can do
JMOR
05-30-2014 18:13:19
 Re: Lift problems on a 59 Ford 641-D in reply to 59-641-D, 05-30-2014 17:55:34
Quoting Removed, click Modern View to seeFO-20 is an I&T manual available all over the place, including most tractor supply places.
59-641-D
06-06-2014 13:34:00
 Re: Lift problems on a 59 Ford 641-D in reply to JMOR, 05-30-2014 18:13:19
Ok, update.....pulled the cover sent it out for complete overhaul...dropped the plate for the pressure rielief valve.....sludge in the bottom....(mind you this was flushed back in 2008) and sludge in the case itself) get to clean it again. As far as the O-rings, they looked a little chewed and will be replaced with the gasket. I will look into the I&T manuel for the future.....will let you know what happens
JMOR
06-06-2014 13:48:10
 Re: Lift problems on a 59 Ford 641-D in reply to 59-641-D, 06-06-2014 13:34:00
Good luck & do keep us informed.
59-641-D
06-17-2014 14:56:33
 Re: Lift problems on a 59 Ford 641-D in reply to JMOR, 06-06-2014 13:48:10
I will :D
59-641-D
06-23-2014 16:55:11
 Re: Lift problems on a 59 Ford 641-D in reply to 59-641-D, 06-17-2014 14:56:33
Lift is fixed, chatters slightly, maybe due to air in the system.
thanks again:)
JMOR
06-24-2014 05:19:59
 Re: Lift problems on a 59 Ford 641-D in reply to 59-641-D, 06-23-2014 16:55:11
Happy 'lifting'. :lol:
59-641-D
06-29-2014 07:19:45
 Re: Lift problems on a 59 Ford 641-D in reply to JMOR, 06-24-2014 05:19:59
Air is out, works beautifully:)
59-641-D
05-30-2014 18:20:30
this web site, or "Tractor Supply"??
Thanks,
Eddie
59-641-D
05-30-2014 18:24:05
 Re: Lift problems on a 59 Ford 641-D in reply to 59-641-D, 05-30-2014 18:20:30
or does Ford new holland have it???
