Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Tool Talk Discussion Forum
Re: Welding hooks on bucket
nisse
05-29-2014 18:03:53
Thanks for the responses, it is a ac machine. I like the idea of adding some more plate and will use 7018 rod. Will give me a chance to work on my stick welding, don't do as much since I got a mig at home.
Thanks,
John
Donald Lehman
05-30-2014 06:04:58
 Re: Welding hooks on bucket in reply to nisse, 05-29-2014 18:03:53
First off, very few AC welders will work with 7018 rod. I would try a practice weld with 7018 before I went at the hooks. 7014 does not pernetrate as deep as the 6013/6011 rods but is a bit stronger.
Stick welding
05-30-2014 19:13:25
 Re: Welding hooks on bucket in reply to Donald Lehman, 05-30-2014 06:04:58
I think you meant 6010/6011 not 6013. 6011 is actually stronger than 7014. 7014 has more tensile strength but 6011 has better ductility. That's why 6010/6011 are used for dynamic loads and 7014 is used for static loads. Tensile strength is only one factor in overall strength of different rods.
Stan in Oly, WA
05-30-2014 09:16:56
Donald,
Regular 7018 (that is, not 7018 AC) is certainly much more difficult to use with buzz box type welders than many other rods, including 7014, 6013, and 6011, but it can be done. The real problem is that it creates an additional level of difficulty, which is clearly not needed in this situation.
As a point of interest, AC is the recommended polarity for some varieties of 7018, for instance Lincoln rods which end with the designation H8, and all 7018 at higher amperage settings.
Stan
Donald Lehman
06-01-2014 17:56:38
 Re: Welding hooks on bucket in reply to Stan in Oly, WA, 05-30-2014 09:16:56
Thanks for the extra info guys.
dr sportster
05-29-2014 18:21:24
You must realize the pass for that is verticle up . If you have not done those type welds before it may be best to hire someone. You can probably watch that type of weld position on youtube ,but you better practice some verticle upward passes first. Its not like you can turn the bucket on its side [ or maybe you can in which case forget everything I posted haha . so there! .]
JMS/.MN
05-30-2014 09:17:46
 Re: Welding hooks on bucket in reply to dr sportster, 05-29-2014 18:21:24
Direction would depend on how the bucket is made. I have several, JD, Gehl, and generic. All have three hooks, welded on a horizontal surface at the top of the bucket. re testing...I think a massive oak would work...LOL
