TractorLinks.com
Tool Talk Discussion Forum
Re: Water well not producing volume LONG!
Guido
05-29-2014 17:55:17
Hello Leroy,
Read my post again! Bladder pressure WAS 28# a added pressure to bring it to 38#. Pump settings are 40# on 60# off.
I need to get the pump out and see what the bottom looks like. Next week hope to do just that,
Guido.
T in NE
06-01-2014 06:54:40
 Re: Water well not producing volume LONG! in reply to Guido, 05-29-2014 17:55:17
Did you shut off the pump and let the water depressurize before you checked the bladder, like they are trying to ask if you did?
Guido
06-01-2014 12:16:59
 Re: Water well not producing volume LONG! in reply to T in NE, 06-01-2014 06:54:40
Hello T in TN, I pulled the disconnect, drain all the water out, checked the air pressure added 10 lb.
It did run for a couple of minutes, but with one flush it came on again with newer type toilet. Not much water don't you think?
Guido.
showcrop
06-01-2014 13:18:16
 Re: Water well not producing volume LONG! in reply to Guido, 06-01-2014 12:16:59
Yes I agree. How big is that tank? and are you sure that it is not partially waterlogged?
Guido
06-01-2014 15:16:52
 Re: Water well not producing volume LONG! in reply to showcrop, 06-01-2014 13:18:16
Hello showcrop,
I don't know the size, but it is the smallest thing you can by. Next size was $75. That is how much the builder saved on that system times 30 houses!. It has been short cycling with the sprinkler on. I'm going to check the anti blow back valve. If it was leaking, it could be one of the problems.
I'm still thinking the well is not producing the proper volume. This coming week we will know,
Guido.
showcrop
06-01-2014 18:03:55
 Re: Water well not producing volume LONG! in reply to Guido, 06-01-2014 15:16:52
Well, that is it! Get a tank with some capacity and it will be able to flush the toilet many times. You can't expect a tank that will push one gallon to flush your tank more than once. I don't know the volumes but you should have one about four feet high.
Guido
06-02-2014 05:12:36
 Re: Water well not producing volume LONG! in reply to showcrop, 06-01-2014 18:03:55
Hello,
The pump runs too long now, just to fill the little tank. Bigger tank would take longer to fill at this rate. It is a small tank, just another part of the poorly designed system,
Guido.
