Hi. I got an International Harvester, an old '65, in January. I noticed immediately when I'd plow snow into a pile and put front end under pressure, it would lock in gear and couldn't get it into reverse. If I kind of gave it some gas and tried to shift quickly at same time, I could usually get it out of gear with some effort. Then, this spring, when I began cleaning up the barnyard (horses/hay), again if I drove it into the pile and put front end under pressure it would lock in gear. Sometimes if I raise the bucket it would change the pressure points, I guess, to the point I could get it out of gear, but ... It shifts fine when it's not under load on the front end. Wondering if you could tell me what the problem might be.
thanks
Doug
thanks
Doug
