TractorLinks.com
Tool Talk Discussion Forum
Re: Update on the grease tool thingy
Diydave
05-23-2014 17:23:31
Tried it on some harder to get to fittings on a Long hay tedder, today. Even fit it through that impossible to get through hole in the PTO shield, to get to the rear U joint, on one of those modern triangular drive shafts. Also was able to Lube the ORC, behind the rear U joint. If the thingy will bite onto the fitting, even if it is at a 10-15 degree angle, it WILL pump grease in. On the ones that you have to put it on at an angle, it may lose a marble sized blob of grease, but nowhere near the amount you lose with a regular tip...
