TractorLinks.com
Tool Talk Discussion Forum
Shop vac
Bernie/MA
05-23-2014 07:16:32
If you need to get into a tight/deep place cut the bottom off a plastic bottle and shove it onto the hose end. I used a tapered gas antifreeze bottle.
TomR Ont
05-24-2014 20:15:25
 Re: Shop vac in reply to Bernie/MA, 05-23-2014 07:16:32
Bernie/MA,
Be careful you don't over heat the motor, they don't like to get too HOT. BTDTx2
Dick2
05-23-2014 16:18:43
I took a section of plastic extension, heated it with a torch to flatten it so I could use it to vacuum off the coils under the fridge. Works okay.
dr sportster
05-23-2014 08:04:49
I need a special attachment to suck leaves out of the fender of my Caddy . I'll try that .Sounds like what I need .
Bob
05-26-2014 20:41:11
 Re: Shop vac in reply to dr sportster, 05-23-2014 08:04:49
The "special attachment" you require is called a "leaf blower", or simply a non-OSHA-approved straight-through air coupler adapter.
