Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Tool Talk Discussion Forum
Update on the grease tool thingy
Diydave
05-22-2014 16:59:24
I ordered a last week...Update, I got the thingy, in the mail, last night... Went out today, and gave'er a go. Verdict is, best $30 I ever spent, I'm gonna order another couple. I greased all but one fitting on the NH 256 rake, only one I couldn't grease, was the right hand drive shaft U joint, and that was because it was pointed inward, and I couldn't move the rake, cause it wasn't hooked to a tractor... Also greased up the Hesston 5530 round baler, and got all the fittings. This thing is only about 10% longer than a standard tip, and maybe 1/16" bigger in diameter. I also didn't lose nearly as much grease, as I do with a normal tip. Makes greasing a easier job, for sure! Oh, and greasing the hay equipment made it rain pitchforks and broom handles, too!
55deere70
05-26-2014 03:45:04
 Re: Update on the grease tool thingy in reply to Diydave, 05-22-2014 16:59:24
OK, OK, I'm convinced I'll order one and give it a try. I hate wasting grease. Seems you can't get a quality tip these days that won't leak grease.
Tim (Ga)
05-23-2014 17:40:06
I got one of them grease thingys and it works great. I will be ordering at least two more. ThNks diydave for posting about this grease gun adapter.
Diydave
05-23-2014 17:23:31
Tried it on some harder to get to fittings on a Long hay tedder, today. Even fit it through that impossible to get through hole in the PTO shield, to get to the rear U joint, on one of those modern triangular drive shafts. Also was able to Lube the ORC, behind the rear U joint. If the thingy will bite onto the fitting, even if it is at a 10-15 degree angle, it WILL pump grease in. On the ones that you have to put it on at an angle, it may lose a marble sized blob of grease, but nowhere near the amount you lose with a regular tip...
Dr. Walt
05-23-2014 09:45:40
Neat little gizmo, now if they would just make one for Button Fittings. LOL
Doc
mkirsch
05-23-2014 05:41:26
Quick tip on greasing the U-joints of a NH 256 rake:
You don't need to move the rake to get the U-joints in a position where you can grease them.
Just put the rake in gear, and slowly spin the rake bars by hand, until the shaft turns to where you can get at the fitting.
This works for any rake with a ratchet clutch in the wheels, like the NH 56, 256, 258, 259, etc.
We used to struggle to get at the fittings on the U-joints, but I discovered that when you stop, and the basket keeps turning, the shafts keep turning too. That's what the "click-click-click" is.
Diydave
05-23-2014 17:15:32
 Re: Update on the grease tool thingy in reply to mkirsch, 05-23-2014 05:41:26
OK, I learn something new each day. Trouble is, my forgettery is much better than my memory!
Kerry50
05-23-2014 04:42:55
Told ya...Finally a new thing a ma jig that works like it should.
Mark W.
05-23-2014 04:08:20
Whats the name of it and where'd you order from? Thanks for review.
Diydave
05-23-2014 17:14:10
 Re: Update on the grease tool thingy in reply to Mark W., 05-23-2014 04:08:20
Here's the link, It's sold from the site, 29.99, shipping included.
CAS
05-22-2014 22:38:24
I got mine yesterday. Two farmers stopped at my shop and we went out in the yard and found about a dozen of the worst fittings we could find. It worked without leaking and broke grease through every fitting. Both guys asked me to order 4 "lock and load" ends for their use.
I got mine on ebay same thing same price and no ahipping. The guy even pays shipping if you do not like it.
The only thing that is a little odd I noticed it is made in South Africa. At least it was not from China. Still it is quite impressive for what it is used for.
andy c
05-22-2014 17:24:43
A very good product! holds on to those tough ones. Only wish I had thought of it!
JRSutton
05-22-2014 17:12:56
ok you guys are slowly convincing me.
We'll see what dalex thinks.
I usually don't go for gimmicky little special tools like that... but maybe. I do like the concept.
Dalex
05-25-2014 11:17:35
 Re: Update on the grease tool thingy in reply to JRSutton, 05-22-2014 17:12:56
JR : I got mine yesterday , and it works perfectly. No leaks and it really stays put ! Now for the longevity test , we'll see in 5 years !
Diydave
05-22-2014 17:08:56
I just ordered 2 more!
Dalex
05-22-2014 17:03:14
I've got one ordered too , I'm waiting by the mailbox !!
woodbutcher
05-23-2014 03:36:05
 Re: Update on the grease tool thingy in reply to Dalex, 05-22-2014 17:03:14
Okay, I'm sold on 'em. I've noticed lately, though, that my grease guns don't seem to last very long. When I put in a new tube, they work okay. But when it gets down to half, they won't pump any pressure to get the grease moving. Am I just buying low-quality guns?
Butch
CAS
05-24-2014 07:23:39
 Re: Update on the grease tool thingy in reply to woodbutcher, 05-23-2014 03:36:05
I think you grease guns are getting air locked.
Just loosen the theaded end pick it is almost off
and pump till you get grease. Then tighten it up.
Also, I have taken the tube and fitting off and pumped a few times. Seems to work to.
If that does not work, I would throw the grease gun on the scrap pile.
ypop
05-23-2014 08:37:07
pull the spring loaded handle at the tube end and rotate when it is under pressure. This usual works for me.
woodbutcher
05-24-2014 04:23:12
 Re: Update on the grease tool thingy in reply to ypop, 05-23-2014 08:37:07
Thanks, I'll give that a try.
Diydave
05-24-2014 16:49:12
 Re: Update on the grease tool thingy in reply to woodbutcher, 05-24-2014 04:23:12
If you store a grease gun, where it will get wet with the weather, the cartridges, which are made of paper, which can swell up, and deform, causing a jam, and the loss of half a tube of grease.
