Gas weld tips
Tequila
How does Foyner weld tips match with Victor. I need a victor OO size tip.or a Foyner tip the same size. No one close by carries Victor??
Victor should have a listing with the size of hole. It's a pretty small tip though. Do you mean Forney? You have to make sure the the tips will work on a Victor torch.
Do you mean Forney? Victor should have a listing with the size of hole, maybe Forney does too. It's a pretty small tip. You could use a tip cleaner to compare sizes. You have to make sure the the tips will work on a Victor torch.
