Yesterday's Tractor Co. Restoration Quality Tractor Parts
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Tool Talk Discussion Forum
Info on generator?
Rickieblue
04-18-2014 14:29:14
173.87.159.209
I see a McCulloch Mite-E-Lite generator coming up at an auction. It doesn't look like it has been used in a while. Does anyone have any good or bad stories on one of these? It is a 3300 watt unit. I shy away from all of the newer gen sets as most come from the land of almost right. Thanks for any info you can give me! If you are unsure of this particular generator, click on the link!
[Reply]   [No Email]
bill mart
04-19-2014 13:24:33
69.204.67.49
 Re: Info on generator? in reply to Rickieblue, 04-18-2014 14:29:14
basically a collectors item , there is a fan club out there if you search the internet. I just picked up a 4 hp unit for $75 this winter. Runs and generates fine. Dont plan on using it for emergency power just think its cute looking. Got a second one that the carb and gas tank are gummed up . bill
[Reply]  [No Email]
Billy Shafer
04-19-2014 06:05:19
67.141.106.135
Not something you would want. Unless you like seeing smoke. Had four in my shop at one time.Bearing failure was common. Which let the rotor hit the stator and let the smoke out. Also parts no longer out there for the gen section
[Reply]  [No Email]
buickanddeere
04-19-2014 06:03:01
184.151.36.226
Any portable generator should not carry a sustained load of more than 75% of it's rated continuous capacity .
Watch the "name plate" capacity rating. It's often a peak or 2 minute intermittent duty rating. Not the continuous rating .
The brand Champion has an American head office with equipment built in China to spec. Champion appears to have high quality specs and they keep checking to make certain the Chinese don't start cheapening the manufacturing.
I know of several units and they work as well as any comparable Yamaha or Honda.
This post was edited by buickanddeere at 06:07:31 04/19/14.
[Reply]  [No Email]
ih_bug
04-18-2014 23:31:12
66.206.229.210
I had a couple the problem was the thrust bearings would not stand the side load, and the flywheel (armature?)would rub the copper coils and short things out.
[Reply]  [No Email]
Bob M
04-18-2014 18:46:41
65.110.157.186
In the early 90's an elderly neighbor had a smaller (1.5 kw?) Mite-E-Lite with a 3-1/2 HP B&S engine.
It ran pretty much non-stop for 8 or 9 days during an area-wide power outage (ice storm). It powered his sump pump, the boiler circ pump and a couple small lights.
Only problem is the generator's tank held only enough fuel for about 1-1/2 hours of operation. Otherwise it seemed like a decent unit.
[Reply]  [No Email]
Gene Davis (Ga.)
04-18-2014 18:28:27
98.80.239.195
I was a Mc Culloch dealer in the 1960- 70's and only sold one of these units. It had poorly designed field coils. The slightest overload condition let the magic smoke out, The owner finally got tire of sending it back for warranty repair and abandoned it. If you keep the load under the rating and it might last.
[Reply]  [No Email]
boler76
04-18-2014 14:38:48
184.151.63.221
the generator hangs on the motor shaft and the shaft tends to break after a while, Seen a couple that did that
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Posting Help]  [Return to Forum]   [Add a Reply]
TRACTOR   PARTS TRACTOR   MANUALS
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2014 Yesterday's Tractor Co.
