air compressor replacement
schrade
Think air compressor at shop going out found a metal chip in relieve valve and not pumping up as fast what should we replace with have a 60 gal upright cambell hausfeld thinking of just compressor not whole unit
It isn't all that difficult to overhaul a compressor pump. You can find kits on ebay that has the gasket sets as well as flapper valves and rings. Really all you would need as far as equipment is a cylinder hone.
A lot of those "read" valves can be made from a fealer gauge. Go to NAPA and get one of the long ones and cut to the size you need.
