TractorLinks.com
Tool Talk Discussion Forum
air compressor replacement
Schrade
03-30-2014 08:53:23
Think air compressor at shop going out found a metal chip in relieve valve and not pumping up as fast what should we replace with have a 60 gal upright cambell hausfeld thinking of just compressor not whole unit
jeffcat
03-30-2014 20:23:31
 Re: air compressor replacement in reply to Schrade, 03-30-2014 08:53:23
A lot of those "read" valves can be made from a fealer gauge. Go to NAPA and get one of the long ones and cut to the size you need.
LOU from Wi.
03-30-2014 16:43:57
heres a link to surplus center, need to look for hp of your motor to match up cfm.
Hope it helps,
LOU
Stephen Newell
03-30-2014 11:32:25
It isn't all that difficult to overhaul a compressor pump. You can find kits on ebay that has the gasket sets as well as flapper valves and rings. Really all you would need as far as equipment is a cylinder hone.
Stick welding
03-30-2014 11:06:30
Tank size doesn't tell anything. How many CFM's do you need? Some punctuation is nice too.
Hobo,NC
03-30-2014 09:16:33
http://www.ebay.com/itm/1120-335-Kellogg-Air-Compressor-Pump-Equivalent-/370752473942?pt=LH_DefaultDomain_0&hash=item565291cb56
