How does one remove the top of a 79 Buick Regal 4 bbl carb? The pump rod and a choke rod on the opposite side of the carb go down the sides and I see no way to pull the top off.
The problem is the engine will only run with spurts of engine starter spray. The fuel pump has been replaced. The filter is new and very hard to blow thru as are the new ones at the store. When I loosened the top of the carb, plenty of fuel ran over the sides at the bowl. Can it be a stuck shut float valve?
Thanks for your assistance.
Slowpoke
Slowpoke
