JD 330 Baler
If your baler is configured the same as the larger JD balers, the hydraulics close the door and then close the latch. Give a one thousand one count before you release the SCV lever to give it time to latch after you feel/hear the door close. Also, what the others have posted; you need a manual, and a SCV valve that doesn"t hold pressure will let the door open and will also affect bale density.
Bob
