Converting metal chop saw?
I have a metal chop saw that I am not happy how it works. I like using thin cutting disc for angle grinder instead. I am going to be doing some laminate flooring and need something to cut with. Is it possible to put a wood cutting blade on the chop and have it work?
Should not be a problem at all, going the other way can cause trouble. We sell one at work now that is rated to cut wood or steel with the same blade.
