sandblasting
I intend to sand blast some wheels and cast iron parts outside. Do any of you build a containment system to retrieve the blast medium? I am thinking of putting up a tarp in an open end shape to keep the medium from blowing all over, with a tarp floor so I can recover it. Any suggestions would be appreciated.
I've done outside blasting quite a lot by using the same procedure you mention . But a problem I encountered a lot was dampness from the ground . Even tho I had cardboard & a tarp or sheet of plastic on the ground to catch the sand , it picked up dampness before I could get it all sifted & back into my blasting tub . So maybe when the sun is out & ground is warm , you may be ok . Post back how it works out for you . God bless , Ken
Thanks. I think I'll build my tarp structure on the bed of a trailer, so the medium doesn't touch the ground and so it'll be easier to pick up on the base tarp and filter into a bucket. Is 1/4" hardware cloth small enough to use for a filter?
Yea, but usually not worth the effort. Bare ground, gravel or grass heals from blasting. Concrete or blacktop is etched by blasting so in twenty years you'll still see a outline of the exhaust manifold in your driveway.
I did something similar. I had a tarp down to catch a lot of it. I also cleaned it a little by pushing it slowly off a shovel in front of a box fan. The dust blew away. I then put it back in the hopper along with some new media. I had no moisture issues. probably because it was in the winter below freezing.
(quoted from post at 14:26:48 03/21/14) Thanks. I think I'll build my tarp structure on the bed of a trailer, so the medium doesn't touch the ground and so it'll be easier to pick up on the base tarp and filter into a bucket. Is 1/4" hardware cloth small enough to use for a filter?
And no 1/4 inch is not nearly fine enough to sift the sand with.
I use kinda large aluminum screen wire. It is actually screen from an old seed sifter for little seeds. Grass seeds I think.
I did that a lot. I had several sheets of used plywood and sort of propped up a stall type set up with a tarp on the ground. Caught a lot of it and reused it. The sand breaks down with use but working out side a lot of the "dust" drifts away. I live in the sticks so it doesn't matter if I dust a little. You need a fine screen to sift. I have two of those cheapo Sears siphon blasters that I just use the buckets from with the screens to sift it. You must have a fine enough mesh. After the 50th time you stop to clean your nozzle or hose you'll know why. BTDT
Try and find a good mask or respirator, whenever I sandblast I can tell it in my lungs/breathing the next day. chris
