Yesterday's Tractor Co.
Shop Now View Cart
Tool Talk Discussion Forum
Re: 3 phase converter
01-31-2014 11:05:26
Power feed on table usually is run with 120V, separate from the spindle motor. I haven't run a mill using a VFD yet, but I have looked into it. Advantage is that the speed can be controlled instantly without changing pulley size. Some info here -->
I run my lathe and Bridgeport using a rotary converter. I bought the control box from Anderson Converters 3HP panel is $169, then just add a 3HP 3phase motor as an idler. Very simple to wire, and works good. I just bought a 10HP panel from them to set up another converter for a larger lathe and surface grinder.
