Yesterday's Tractor Co. Compare our Prices For Parts
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Tool Talk Discussion Forum
Anyone familiar with Anode Rods in water heaters?
Dick2
01-30-2014 13:49:13
97.117.177.33
I'm reading online that aluminum rods are prefered over magnesium. Al is $10 less than magnesium.
Anyone have any words of wisdom about anode rods?
[Reply]   [No Email]
Michael Soldan
01-30-2014 17:01:22
24.235.37.221
 Re: Anyone familiar with Anode Rods in water heaters? in reply to Dick2, 01-30-2014 13:49:13
Unscrew it out of your tank,cut it off with your chop saw and screw the stub back in. If you still have smelly water,get a ball valve and nipple and put that in. That way you can shut off you pressure,drain a quart or so out of the tank,open the ball valve and pour in a cupful of bleach and then hook things up again. Never will you have smelly water and the results??? You tank might only last 18 years instead of 20.
[Reply]  [No Email]
MarkB_MI
01-30-2014 15:39:57
75.241.112.192
Magnesium is less noble than aluminum, hence it makes a better anode. For this reason, any water heater with a long warranty is going to have a magnesium anode. However, if you have problems with sulfur smell in your water (like I do), it's going to be worse with magnesium than with aluminum. I replaced the original magnesium anode in our heater with an aluminum one; it improved the sulfur smell but didn't completely eliminate it. If we're gone for a few days the smell will come back.
[Reply]  [No Email]
Steve@Advance
01-30-2014 14:48:51
108.245.66.82
Found this, no personal experience with one though. Just wonder what the odds of getting the old one out without starting a leak or twisting the end off.
Water Heater Anode Rods - Additional Information
Aluminum Anode Rods - Least expensive of the anode rods we offer and normally corrode at a slower rate than other anode rods. Most water heater manufacturers install these in their water heaters as standard equipment.
Magnesium Anode Rods - Normally corrode at a slightly faster rate than most anode rods, but dissolved magnesium in water can offer many health benefits.
Aluminum/Zinc/Tin Anode Rods - This combo rod is designed to fight some foul water odors that can occur in water heater systems that use aluminum or magnesium anode rods. Please read our FAQ for more information regarding water odor.
Hot Water Outlet Style Anode Rods - This style of anode rod installs into the hot water outlet of the water heater and yet allows the water to still flow through the outlet. These allow the installation of an anode rod for those instances when the normal anode rod has corroded too much causing the steel to rust or corrode in such a way it is now impossible to remove the old rod. Or, for those who just wish to add a second anode rod into the water heater for better protection. Please note: Some water heater hot outlets can have a calcium build up inside the outlet, or the tank may have not been properly bored out underneath the outlet opening, possibly causing interference with this rod slipping into the water heater.
Hot Water Outlet Aluminum/Zinc/Tin Anode Rods - Contain a built-in heat trap nipple with a fluoroplastic ball that sinks inside the nipple, into a seat, as water flow stops. This is designed to keep any cooling hot water from entering back into the water heater potentially cooling the water heater down. The seat is equipped with a safety relief port. When water is not flowing, heat is effectively trapped in the water heater reducing standby heat loss.
Hot Water Outlet Aluminum Anode Rods - Least expensive of the hot water outlet styles, this particular anode rod has a built-in dielectric nipple (no ball or seat) allowing less water restriction than a heat trap nipple.
Flexible Anode Rods - Used when access to the top of the water heater has limited clearance due to any obstruction such as low ceilings in closets, attics, under stairwells or in basements. The anode rods are manufactured into three or four sections connected with a solid steel wire or stainless steel braided wire. The Flexible Aluminum Anode Rod has three sections of aluminum attached to a solid 1/8" low carbon steel center wire core. The aluminum will corrode and disintegrate before the steel wire can. The Ultra Flexible Magnesium Anode Rods have four sections of magnesium on a steel rod. The sectional connections are made with copper couplers and 301 stainless steel braided wire providing greater flexibility during installation.
[Reply]  [No Email]
George Marsh
01-30-2014 14:10:16
50.121.7.90
Not that familiar. Was told by a person with a water softner, they removed their anode. They claimed it made their well water stink.
I've never replaced one. Just use what comes from the factor. When water heater rusts out and leaks it time for a new water heater.
[Reply]  [No Email]
Rich_WI
01-30-2014 21:06:12
50.50.82.205
 Re: Anyone familiar with Anode Rods in water heaters? in reply to George Marsh, 01-30-2014 14:10:16
You might want to brush up on anode rods, they prolong the time it takes for a tank to rust out. A little maintence on an anode rod saves lots of time and money by not having to replace water heaters.
http://www.plumbingsupply.com/anoderods.html
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Posting Help]  [Return to Forum]   [Add a Reply]
TRACTOR   PARTS TRACTOR   MANUALS
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2014 Yesterday's Tractor Co.
