guido
Hello,
Had a chance to look at the washer today.
It has no idler or tensioner system, single multi groove belt. Tub side of belt has no grooves. I tighten the belt a bit, and tried a small wash. It will empty about 1/2 of the water, and at the 12 minute time comes up with a error code. It is for an unbalanced load. The agitators are moving when it spins, that puts the load out of balance.
With no clothes in the washer, it will spin fast and remove all the water. It seams a bit out of balance, but it works, and NO CODE! What is wrong with this machine I think, is whatever makes the two agitators park, so they are balanced and don't move. All I saw was the pulley attached to the bottom of the drum,
Guido
Guido
