Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Tool Talk Discussion Forum
Re: laminate floor install
kris Jensen
01-09-2014 21:28:24
My experience suggests ripping the foam padding out. If it still looks good you have an anomaly. by now it should be turning to dust, and I suspect it is not far from there. If you have a good strong level sub floor, put your laminate on that. I took out a twenty year old carpet (builders special) and found the foam was weak in spots. took it out, put a few screw-nails in a couple squeaky places and put an engineered hardwood (floating- edge glued) over a special 1/8 inch underpad. Very happy with the result.
Sounds like you have a good project- good luck
