TractorLinks.com
Tool Talk Discussion Forum
Re: Anybody do double-throw switches these days?
Charles (in GA)
01-08-2014 18:52:59
If you don't have, or expect to have a 200 amp generator, then a 200 amp DPDT switch is a waste of money.
An interlock on the panel, allowing say a 30 amp breaker in the upper right, fed by the generator, and the main breaker, to be interlocked so both cannot be on at the same time, is doable for most situations.
The GenerLink does the same thing, powers the panel with up to 30 amp from a generator, but does it at the meter. This may be a better choice if you have a Main Lug panel, or you would have to add a main breaker conversion to use the interlock kits. Difference is cost GenerLock is pricey, and that the Power Company will have to approve and install it, as its their meter it is plugging in underneath.
Square D QO interlock is about $50+ on Ebay plus another $50 for a generator inlet box plus wire and installation.
Charles
Dusty MI
01-09-2014 05:00:23
 Re: Anybody do double-throw switches these days? in reply to Charles (in GA), 01-08-2014 18:52:59
If you can set your panel main so the main breaker is beside the generator breaker, an interlock bracket is only about $15.
Dusty
