Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Tool Talk Discussion Forum
Re: Anybody do double-throw switches these days?
buickanddeere
01-08-2014 15:59:00
JML755 said: (quoted from post at 12:44:48 01/08/14) mkirsch,
I agree with David G. Put in a manual switch. It'll take a couple of hours to install it next to your main panel. The actual wiring took me maybe 15 minutes of that on a 6 circuit version. No messing with the main feed, you just disconnect the "hots" off each breaker you want on the switch, wire-nut them to a wire from the switch and put a wire from the switch to the breaker. Most of the time was putting up a board for the switch, punching a hole in the outside wall and feeding a cord through for the generator connection outside the house.
The 6 circuits I chose give me power on all the critical items (fridge, furnace, etc) plus a light circuit and outlet in each room of the house.
After I throw the switch to "generator" on the 6 circuits, I leave a light on in the hallway (not on the generator circuits) so I know when the power kicks back on.
Since I'm only going to be in this house for a couple more years, I didn't bother with an auto system. THAT will be on my next house.
Never seen such a waste of time to cobble on four or six circuits out of 20+ in the panel. Lights draw very little power but are handy and there is less tripping in the dark. Just switch the entire panel with a Generlink, or main breaker/generator inter-lock safety slide.
http://www.reliancecontrols.com/ProductDetail.aspx?TWB2012DR
This post was edited by buickanddeere at 16:01:44 01/08/14.
IH2444
01-08-2014 16:14:36
 Re: Anybody do double-throw switches these days? in reply to buickanddeere, 01-08-2014 15:59:00
Umm then you have to turn off the water heater breaker,etc.
And the wife would be running the vacuum.
Now if you have a 200 amp generator that would be fine.
jgayman
01-08-2014 17:38:46
 Re: Anybody do double-throw switches these days? in reply to IH2444, 01-08-2014 16:14:36
>Umm then you have to turn off the water heater >breaker,etc.
>Now if you have a 200 amp generator that would >be fine.
This is true. But is it very easy. I run my whole house from a 6500W Honda Inverter. I have about 30 circuits and I put little orange stick-on dots next to the breakers that get turned off when running from emergency power. It is basically the hot water heater and central air. Everyone understands the drill.
And... in a true extended emergency, if I find myself needing more hot water I **can** run the hot water heater from the generator if I turn off a bunch of the other breakers until the water gets hot. I tested it last summer. The water heater showed 5500 watts on the generator's wattmeter.
