Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Tool Talk Discussion Forum
Re: Log splitter woes
PJH
01-08-2014 09:02:07
Don't know about strapping the cylinder - mine has a lot of movement, but it's 35+ years old and well worn.
My son bought a "new" splitter from Rural King. It had been returned as defective - someone had abused it somehow and bent the cylinder shaft. It was obvious to even a casual observer, and he got it for a fourth of it's normal price. (He should have offered less - the manager almost jumped through his hat accepting his offer) Long story short - he straightened the shaft himself, using ordinary tools, without removing the cylinder. He's been using it for about three years since he straightened it. I've forgotten exactly how he straightened it, but I'll check if you're interested.
dbnga
01-08-2014 14:42:49
 Re: Log splitter woes in reply to PJH, 01-08-2014 09:02:07
I am very interested in the method he used to straighten the shaft. Thx.
PJH
01-08-2014 17:48:25
 Re: Log splitter woes in reply to dbnga, 01-08-2014 14:42:49
Just talked to son. He extended the rod all the way and used a porta-power jack slid between the cylinder rod and the beam. He disconnected the rod end of the cylinder only, and raised it up to provide clearance for the porta-power. He used blocks of wood with V-cuts in them to protect the shaft. Blocks of wood with V-cuts and log chain were used to anchor the rod end of the cylinder to the beam, and two more chains/blocks were used to isolate the area that he wanted to bend. With the cutter disconnected from the cylinder rod, you can rotate the cylinder rod to your advantage (with bend toward the beam). Like straightening a bent lawnmower crankshaft, he had to over bend it a little and let it come back straight. It was all strictly eyeball work. He cautions you to be very careful with fingers, eyes, etc., and if this is not your area of expertise, just don't fool with it. Son mechanics for a living, and is comfortable with projects like this. He also said to tell you that the shaft has bent slightly since he straightened it, (I didn't know that) and he's going to build a bracket to tie the mid point of the cylinder to the beam, as you originally suggested. He has about $300 in this splitter, and did not have much to lose if it wouldn't straighten. His shaft was pretty badly bent when he bought it - enough that you could spot it from across the store parking lot. Let us know how it turns out, and good luck with what ever you try.
dbnga
01-08-2014 19:54:24
 Re: Log splitter woes in reply to PJH, 01-08-2014 17:48:25
Thx for the info, I have the means to try the exact same process, but never thought of it. I will let you know how it turns out.
bison
01-08-2014 22:41:21
 Re: Log splitter woes in reply to dbnga, 01-08-2014 19:54:24
Motorized Log splitters are for lazy people.
Mine helps keeps me in shape :lol:
PJH
01-09-2014 06:25:52
 Re: Log splitter woes in reply to bison, 01-08-2014 22:41:21
You've got it shined up good!
When I was a young man, I cut a heaping truck load of dead elm and hauled it home. Dad used to say that you could split the elm with the red center, but not the elm with the white center, or wait - was it the other way around? He was dead and I couldn't ask him. Anyhow - after unloading it, I found that I had the kind that wouldn't split. I couldn't even get a splitting wedge to stand up in it. I loaded it up to take back to a ditch on the farm, but I stopped at the corner gas station on the way. As I was there, an old timer came in and commented on the wood I was "bringing home". I told him the story, and he laughed - said HE could split it. I bet him a soda that he couldn't. I have to say - he was a big man, and he DID get a wedge to stand up in it, but when he'd roundhouse it, the wedge would jump as high as his head. He really drew a crowd, and we all took another try at it - and all failed. I really enjoyed that soda, and the friendly razzing that went with it.
You're right, we've gotten lazy. . .
teddy52food
01-09-2014 18:42:58
 Re: Log splitter woes in reply to PJH, 01-09-2014 06:25:52
Around here in mid Mn. the elm can be split by taking a slab off the sides. It won't split straight across.
PJH
01-10-2014 07:03:45
 Re: Log splitter woes in reply to teddy52food, 01-09-2014 18:42:58
Yeah, there's tricks to splitting it. Start around the outside and work your way in. That's what the old timer was gonna show me, but this particular tree was like trying to split an anvil.
I don't have any trouble with elm, now that I'm "wealthy" enough to own a splitter, ha. Some of it will make the splitter cry the blues though.
Sycamore is what I hate to mess with. It's stringy, and won't separate until the last inch. It's undesirable as firewood, but I have a creek bottom that grows it too well, and if I cut it, I'm gonna burn it. It's spring and fall firewood - it just doesn't have the heat in it that hickory and oak have.
D beatty
01-08-2014 23:36:53
I have both . If I can't get it to split by hand I use log splitter. There are some woods that aren't worth beat you your brains out.I throw all the pieces that don't want to split by hand in a pile and when it gets big enough I drag the log splitter out.
dbnga
01-08-2014 22:48:32
I thought that too when I was bulletproof, but now that my joints are rusty, I have to improvise, bite the bullet and use mechanical power every chance I get. Have riding lawnmower for less than 1/2 acre of grass so I can walk the next day after cutting...rusty joints are a b!@+h.
